UDF - C_NFACES
Old   December 10, 2002, 18:49
Default UDF - C_NFACES
St.Schmidt
Dear All,
In a routine DEFINE_SOURCE(name,c,t,dS,eqn) I want to get the number of cell faces by setting
int n = C_NFACES(c,t); /* it should be integer */
to run a
c_face_loop(c, t, n) {...}
My problem is that I get an error message from the compiler. I am not v/good at C as you can imagine by my question. I have tried to put C_NFACES(c,t) directly into the loop header c_face_loop(c, t, C_NFACES(c,t)) - but with no success.
Any help appreciated.
Stefan
Old   December 11, 2002, 03:11
Default Re: UDF - C_NFACES
Markus
Hi Stefan,
Most likely your problem is that several macros simply do not work in interpreted mode, among them is C_NFACES. The workaround is to use the compiled mode which definitely works.
best regards,
markus
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
