December 11, 2002, 00:48 |
Error Message in Multiphase Problem
I am trying to run my model in FLUENT using multiphase model(3D/Euler/K-E/Seggregated).On initializing inlet for the initial values, it gives me the error " Turbulent Viscosity limited to visosity ratio of 100000 in 166339 cells. Internal error at line 2405 in mp_press.c . bc_type not handled. Error object()". I have taken inlet to be mass flow inlet.
Please let me know where am I going wrong? |
December 13, 2002, 03:10 |
Re: Error Message in Multiphase Problem
Dear Pravin, U r not capturing the viscous layer. Refine the mesh near the boundary. " Turbulent viscosity...." message comes for that only.
December 13, 2002, 18:37 |
Dear Atul,
Thanks for the reply. I would like to tell you that I ran the same model using velocity inlet instead of mass flow inlet and it ran perfectly fine. Could you tell me why was there a problem with mass flow inlet? Also there are couple of problems which I would like to ask you: (1)I am using air+smoke particles(aerosols i.e. solid). Whic one out of multiphase/multispecies/discrete phase modeling shud I go for? (2) Also I have to calculate the deposition in the lung. So how do I plot the contour for deposition i.e which factor/variable in FLUENT gives me the deposition? Thanks for the help!!! |
Complex multiphase melting problem | leff | CFX | 12 | March 18, 2014 16:46 |
Mass conservation in multiphase problem | cna | FLUENT | 6 | April 4, 2010 10:16 |
UDF problem in multiphase model | Amir Khodabandeh | FLUENT | 1 | March 13, 2009 08:43 |
Problem of B.C. in Eulerian multiphase model | Derek Jing | FLUENT | 0 | May 12, 2002 11:52 |
CF4 - need advice on setting up multiphase problem | Brett Towler | CFX | 2 | August 18, 2000 16:38 |
