small problem
Old   December 9, 2002, 07:18
Default small problem
amiroamir
how can i watch the results in the different level of meshes.i mean i have a 3d model and i cant see the result after run the programm in the different level of elements.just in the bed or wall or... . thanks
Old   December 9, 2002, 10:55
Default Re: small problem
Sohail
You can define surface or line in u r geometry at any location u wanna see the result to do so from surface>>line/Rack and define u r plain or what ever.. hope it work for u Regards Sohail
Old   December 12, 2002, 01:23
Alamgir
u also can create the surface with many options then see the results on that surfaces.
Alamgir
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
[Other] Shadow wall region problem amoolraina ANSYS Meshing & Geometry 0 July 25, 2010 21:17
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
[Other] surfaceCheck problem vivien OpenFOAM Meshing & Mesh Conversion 0 May 7, 2010 04:24
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 09:11
