How to apply heat flux condition
Old   January 7, 2003, 18:47
Default How to apply heat flux condition
L. Zhu
Hi, guys: Could you please help me to apply the heat flux boundary condtion at wall surface. In my case, the known boundary conditions is heat flux, given by: heat flux=heat transfer co. *(Averaged fluid temperature - constant) in which heat transfer co. is constant, but the average fluid temperature varies at different locations in the simulation domain. Thank you very much!
Old   January 7, 2003, 22:05
Default Re: How to apply heat flux condition
zhhuang
you can apply the heat flux by boundary condition ,and you can get the bulk temperature [maybe the Averaged fluid temperature ]using Fluent.
Old   January 8, 2003, 10:16
L. Zhu
Zhang:
Did you suggest me to use UDF to get the bulk temperature? Becuase in my problem, the heat flux is a function of bulk temperature. In UDF, the heat flux is applied on wall surface, which could be defined by Macro DEFINE_PROFILE(). And the temperature can be accessed by DEFINE_PROPERTY(). Now the difficulty is: (1)How to load PROPERTY from PROFILE; (2)The Macro PROFILE()should be update in every iteration. How to make it work? If possible, please give me more advice?
Variable name for heat flux peterle CFX 4 February 13, 2014 02:21
Heterogeneous heat flux Kev STAR-CD 4 July 7, 2009 04:48
how to impose experimental dat as boundary conditi Rogerio Fernandes Brito FLUENT 14 November 25, 2008 05:47
outlet heat flux on bondary condition asghari FLUENT 0 August 19, 2006 04:22
heat flux to heat rejection azmir Siemens 0 June 23, 2004 20:53
