Flow interaction per chemistry update in FLUENT . |
February 4, 2003, 15:25 |
Greetings. Did any one implement the option of Flow iteration per chemistry update in FLUENT 6 ? This option is mentioned in the respective HELP panel for Define-->models-->species-->turbulance-chemistry interaction, but not given!.
Thanks for any respective literature/dissertaion refference, i.e. directly related to FLUENT. Thanks Peter |
February 5, 2003, 05:50 |
Re: Flow interaction per chemistry update in FLUEN
I think you need to select the Eddy Dissipation Concept first before you can select this option.
February 5, 2003, 10:38 |
Erwin Thanks.
Yes I did select EDC 1st but, the EDC model window (i.e. within the spEcies model)does not portray an option of "Flow Iterations per Chemistry Update", COTRARY TO WHAT Is indicated in the respective HELP panel! That is exextly the point of my note and my search for a respective FLUENT related UDF or FLUENT inherent nobe! Peter . |
February 6, 2003, 03:43 |
I checked, I have seen this species menu behave a bit wacky in the past. Indeed, the 'flow iterations' thing does not pop up the first time. First you have to click OK, then it should be there when you go back again.
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
reversed flow in unsteady simulation with dynamic mesh (fluent 12.1) | zhaoyu_001 | FLUENT | 0 | April 7, 2010 00:24 |
swirling flow in simpleFoam compared with FLUENT | belinda | OpenFOAM Running, Solving & CFD | 0 | November 2, 2009 03:57 |
Unsteady Flow in FLUENT | Vidya Raja | FLUENT | 0 | November 1, 2005 17:54 |
Compressible flow simulation using FLUENT | arun | Main CFD Forum | 0 | February 16, 2004 15:44 |
