Fluent
Old   February 11, 2003, 19:02
Default Fluent
Chris Sironda
I am getting AMG solver: Temperature error. I would like to know how this can be solved. Actually, I adjusted my solution controls to 50%,[pressure,Density,Body forces,Momentum, Energy] but still I get the same error.
Old   February 12, 2003, 09:11
Default Re: Fluent
zhhuang
Sironda, When I use the periodic flow,and the flow direction is wrong ,I will get this information,you should check the flow direction if you use periodic flow.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
