Help-UDF
Prev Previous Post   Next Post Next
Old   February 13, 2003, 19:19
Default Help-UDF
ravi
Hi, Sorry to be a pain in the neck..but i need help to set my inlet boundary condition as function of velocity profile. Basically my model has a depth of 30mm and i need to set the inlet condition as a UDF function in C prog. The velocity at 4 different points are..
depth 24mm - 0.23m/s depth 18mm - 0.28m/s depth 12mm - 0.33m/s depth 6mm - 0.38m/s
Can someone pls draft me the C prog for this function, i know its only a few lines but i am really bad at C prog. Pls..thanking you in advance, i really appreciate it
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
