How to let Fluent recognize diffrent faces
Old   March 1, 2003, 16:35
Default How to let Fluent recognize diffrent faces
Steven
I am trying to implement a user defined scalar with UDF. There are three regions with different properties in my mesh, and therefore, there will be three different diffusivities for the mass transfer in these three regions. I could not figure out what macros to be used for this purpose, and how to let Fluent recognize the zones in my mesh. The structure could be something like this:
If region==1 diffusivity=value1; else if region==2 diffusivity=value2; else diffusivity=value3;
My questions are:
What macros to be used? Are threads used by UDF to represent different regions in my mesh? What will be the names of the threads? The names of faces in my mesh? Can somebody give me some ideas or hints? I will really appreciate it.
Steven
Old   March 2, 2003, 21:34
Default Re: How to let Fluent recognize diffrent faces
Murali
<font face = "courier new">After you have imported the mesh into fluent and come to the juncture of specifying boundary conditions, you will find in the boundary conditions panel that you have a zone_id for every region. This number in unchangeable and is assigned internally by FLUENT. This is the number you need to use through "hardcoding" in UDFs. The way to do is to us the Macro Lookup_thread(zone_id). Refer to 6.5.7 of UDF manual.
The diffusivity can be specified by DEFINE_DIFFUSIVITY macro. Suppose I have zone-ids ranging from 3 to 11. First I obtain the domain number, and the cell and thread info are passed into the macro as arguements. I obtain the *thread pointer from the zone-id. If this *thread is equal to the cell thread that is passed, then the corresponding zone-id is the region where the cell belongs. Once I know in which region or zone-id the cell resides, I would know how to assign the value of diffusivity. See the example:
DEFINE_DIFFUSIVITY(my_diff,c,t,i)
int zone_id,i;
Thread *c_thread;
Domain dom;
real diff;
Get_domain(dom);
//Obtain the zone-id of the cell
for (i = 3; i < 11; i++)
if (c_thread == Lookup_Thread(dom,i))
zone_id = i;
//Assign values of diffusivity accordingly
switch (zone_id)
case 3:
diff = value1;
break;
case 4:
diff = value2;
break;
return diff;
</font>
Old   March 5, 2003, 10:03
Steven
Thanks a lot, Murali. I'm working on it.
Shadow Faces in Fluent Kjt FLUENT 6 November 12, 2019 07:45
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
.msh file cann't be by Fluent nchuche FLUENT 1 June 29, 2010 10:38
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
