March 5, 2003, 04:23 |
External flow field.
Hi all!
I have a question. My model has long and wide external flow field. So it has so many cells. So wall has not influence on the flow field. I want to minimize flow field to decrease cell numbers. Minimized flow field has not influence on flow. If I minimize flow field, is it influence on result? |
March 5, 2003, 05:06 |
Re: External flow field.
Hmmm...I could suggest a way to check.
You could have one model with the mesh that is as coarse (minimized, as I think you are calling it) as you want, and then have a second model with a mesh that is just slightly finer (less minimized). If the minimized flow field has no influence on your results, then both should give you identical results. If, however, there is significant difference between the two results, I would suggest you use the finer mesh, and repeat the checking process until you have a mesh of sufficiently resolution for the problem. |
March 5, 2003, 09:43 |
Thank Chris.
'Minimize' mean 'shorten the length of model'. Length of original model is 2 meter and radius is 1meter. I want to shorten the length,1 or 1.5 meter. And radius 0.6 or 0.8. I think that shortened length and radius have not influence on the result. Isn't it really influence on the result?? |
March 5, 2003, 10:32 |
hi, Moon I think Cris' testing method with a little modification is still appilcable for your question. You can create another flow field with different length (maybe as you said 1)and radius (maybe as you said 0.8) and then repeat the calculation again. After comparing the new result with the old one, it is easy for you to decide the effect of such so-call minimizing on the result. However, why not decrease the total cell number by increasing the dimension of cells nearby the boundary region where the change of flow parameters is not very vehement.
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 10:14 |
velocity of massless particles and velocity of flow field in same coordinate | payam_IUST | FLUENT | 0 | October 18, 2009 23:24 |
how 2 freeze 1 phase flow field & start lagrangian | KK | CFX | 5 | February 14, 2008 16:48 |
Reversed flow on external aero problem | Ben | FLUENT | 2 | August 22, 2006 10:05 |
Flow field measurement in turbomachinery! | Wanlai Lin | Main CFD Forum | 3 | September 3, 1999 12:06 |
