combustion of particle in fluent
Old   March 4, 2003, 07:08
Default combustion of particle in fluent
Devy
Now I want to simulate combustion of particle in reacting multiple species flow.There are six laws about particle's heat/mass transfer calculations in fluent.How can I change these laws to suit my problem using a user-defined fuction?
If you have some cases about it,Would you like to give me?
Thank you.
Sincerely, Devy
Old   March 5, 2003, 09:36
Default Re: combustion of particle in fluent
alexandre
I also use dpm for a solid combustion problem. I use inert particles with DEFINE_DPM_SOURCE(dpm_source, c, t, S, strength, p).
There I modify, diameter and use S->Mass to simulate mass transfer.
Hope it helps.
Alex
Old   March 5, 2003, 19:39
Devy
Thank you for your help. But in my problem,both the reactant(Al) and the product of combustion(Al2O3) are particles.This means I must track Al and Al2O3 particle trajectories.Now I just know how to track the reactant(Al) particle trajectories,and I don't know how to track the product(Al2O3) particle trajectories.
Would you like to give me some advice?Thank you.
regards Devy
Particle Tracking CFD-Post Fluent stitrack FLUENT 16 May 21, 2022 00:58
FLUENT 6.3 for particle deposition studies? Prashanth FLUENT 14 September 17, 2015 02:05
coal combustion in FLUENT.. ramakant FLUENT 0 May 1, 2011 00:15
DPM particle size distribution in Fluent Pete FLUENT 5 July 7, 2008 12:22
Premixed combustion using Fluent 6.2.16 Rucy FLUENT 2 December 17, 2005 02:14
