3-D Mesh Check in Gambit.....
Old   March 20, 2003, 23:17
Default 3-D Mesh Check in Gambit.....
SHR
HI all,
I am trying to generate a complex 3D mesh in Gambit 2.0, in which there is a tank having bottom face as irregular (like undulating ground and not a plane surface) surface and other faces are planer faces.
I coud mesh it and export the mesh successfully, but, in FLUENT 6.0 I am got the messages " Grid Check Failed" and "NonPositive Volumes Existed" and as I tried to iterate it showed DIVERGENCE.
Actually in Gambit I created only two volumes which I think are Positive only. So where from the non-postive volums came???
I also do not know what is non-postive volume??
I did check the grid(mesh) in Gambit, but I did not get any clue/warning in Gambit regarding Negative Volume.
Still I am trying to fix the problem.
Regarding Mesh Check in Gambit, I do not know whether I could check it properly, as I doubt now, as to what is the RIGHT PROCESS OF CHECKING THE MESH in GAMBIT.
Please let me know the same in detail so that I can fix this problem.
My geometry does not include any Virtual Volume.
Waiting for HELP..
Thanx in advance...
SHR
Old   March 21, 2003, 03:10
Default Re: 3-D Mesh Check in Gambit.....
Alex Munoz
hello
The following information was copied from fluent web side in order to give you and accurate answer.
The most common error identified by the grid check is negative volumes in the grid. If the minimum volume is negative, you will need to repair the grid to remove this nonphysical discretization of the solution domain. You may be able to use the Iso-Value... marking ability in the Adapt pull-down menu to locate the problem by marking and displaying cells with volumes less than zero (see Section 25.6). For additional information on checking the grid, see Section 5.5.
A negative value for the minimum volume indicates that one or more cells have improper connectivity. Cells with a negative volume can often be identified using the Iso-Value Adaption capability to mark them for adaption and view them in the graphics window. For more information on creating and viewing isovalue adaption registers, see Section 25.6. You must eliminate these negative volumes before continuing the flow solution process.
I faced this problem one time. I meshed again the domain with a diferent decomposition scheme of the domain.
I sugguest that you try to adapt the actual mesh in fluent, if this does not work check all the edges of your domain in gambit, and decompose the domain in a diferent fashion that the actual one.
Best regards
Alex Munoz
Old   March 22, 2003, 01:08
SHR
Thanx a lot Alex!
In your reply you mentioned Section 5.5 & 25.6, where are these available? In our Fluent6.0 installation, the documentation is not working so not able to get help while working. If it is available on internet please give me the link.
regards,
SHR
Old   March 22, 2003, 16:05
Alex Munoz
Hi
You can get this information in fluent webside by clicking in technical support, and then login.
Best regards
Alex Munoz
Old   March 25, 2003, 03:10
Alamgir
Hi SHR,
If there any volume overlaps/dual with other it could be happened. So create the geometry again and see how many volume r there? there r joint or discreate? so move each of the volumes and see any unwanted volume that may be the cause of -volume. It was happened for my case once a time. bye/Alamgir
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[Commercial meshers] gambit import mesh quality problem with checkmesh mrshb4 OpenFOAM Meshing & Mesh Conversion 0 December 26, 2010 13:17
mesh missing after export in gambit morteza08 Main CFD Forum 0 July 23, 2010 02:19
