March 21, 2003, 04:47 |
Gambit 2.0.4-mesh the lake
Hi! I have a problem with meshing a lake. I had build the geometry of the lake using the option in Gambit 2.0.4 "Create real skin surface face" because I had some edges imported from AutoCad2000. Then when I had faces I changed them into one geometry using the "Stitch faces". I healed new geometry and check volume.It was ok. But I should tell that all faces were very long but very thin. Then I mesh faces using the Tri/Pave, interval size 30. I check all faces and they are ok - skewness. If not I mesh them again. But unfortunatly I can't mesh the volume. I had got information about error. Please if you meet with that problem, please give me a know. Best regards. Paulina
March 30, 2003, 07:51 |
Re: Gambit 2.0.4-mesh the lake
can u tell what error message was that,
arjun |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
How to mesh a circle by Gambit? | Zhengcai Ye | FLUENT | 5 | March 24, 2006 01:04 |
[Commercial meshers] Mesh import from gambit | Kaushik Balakrishnan (Balakrishnan) | OpenFOAM Meshing & Mesh Conversion | 5 | April 21, 2005 13:42 |
