Gambit mesh of tangential tube/tube
Old   March 22, 2003, 05:59
Default Gambit mesh of tangential tube/tube
Christian
I have a big tube and a little tube. The little tube is a tangent on the big tube. When I mesh the tangential part, Gambit tells me that the operation has failed.
It properly has something to do with the cells in the tangent point. I think they get too small and too skew (Gambit suggests this).
Do you agree? Do you have any suggestions how to mesh a tangential like that?
Cheers
Old   March 22, 2003, 11:56
Default Re: Gambit mesh of tangential tube/tube
vyrro
Christian,
I had the same problem. I was trying to mesh 2 tubes and I split the at the intersection. When I tried to mesh gambit didn't let me because of the highly skewed elements.
What I did was to unite the volumes and then split them along the longitudinal axes of the tubes. With these gambit didn't have to make elements bounded by 2 colliding surfaces because thre was no surface at the intersection (just empty space). Then I meshed the volume wit tet elements.
I hope I made myself clear.
Old   March 25, 2003, 06:06
Christian
Hi vyrro
I am not quite clear on your split along the longitudinal axis of the tubes. Does it mean that you cut the tube in half making 2 half-circular volumes pr. tube? (was that clear
If I unite the 2 tubes, I can mesh the volumen. But I cannot mesh it with hex as I would like to (I find that hex are more stable numerically and requires less cells).
Maybe the only way to make hex cells are to make an non-conform mesh intersection?
Cheers.
Old   March 26, 2003, 00:04
Alamgir
hi,
U cann't mesh this type of geometry with hex So u have think about the alternatives as the surfaces r not co-linear. Thanks/Alamgir
Old   March 26, 2003, 14:59
Alex Munoz
Hi
you can made a hybrid mesh the main pipe hexahedral the colateral one tetrahedral. In that way you eliminate your problem and oaso the split suguestion that personally I don't like.
Regards
Alex Munoz
Old   March 27, 2003, 03:34
Christian
Hi Alex.
I am not sure I know what you mean. Do you mean that I should mesh the main pipe with hex and the side pipe with tets, and connect the non-conformal meshes in Fluent ?
Cheers
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
[Commercial meshers] Mesh import from gambit Kaushik Balakrishnan (Balakrishnan) OpenFOAM Meshing & Mesh Conversion 5 April 21, 2005 13:42
