compiled UDF
Old   March 25, 2003, 15:46
Default compiled UDF
hedonist
I followed UDF Manual section 7.3 to compile my complied UDF, but after I input command line:
make "FLUENT ARCH=aix43"
I got a message as follows:
make: 1254-002 Cannot find a rule to create target FLUENT ARCH=aix43 from dependencies. Stop.
Do you have any idea what is wrong? Thanks a lot.
Old   March 25, 2003, 19:23
Default Re: compiled UDF
Alex Munoz
Hi
Check if the C compilor has been installed (gcc, or cc)
Copy a short UDF from fluent and Interpreted the UDF if this does not work, You know that something has not been installed correctly
In addtion, are you typing "FLUENT_ARCH=aix53"
because all the characteres are important
Regards
Alex
Old   March 25, 2003, 19:34
Alex Munoz
Hi
Also readed some lines below Compiling UDF Alex Munoz I gave to this person some solution for almost the same problem
Regards
Alex
Old   March 25, 2003, 19:57
hedonist
Thank you very much, Alex. You helped me to figure out one problem: when I printed out the UDF manual, or _ disappear. So I was typing make "FLUENT ARCH=aix43", and that was the reason for that error message. But now I still have problem. I used a very simple code which was fine as interpreted UDF. When I typed in
make "FLUENT_ARCH=aix43"
The message becomes
for d in aix43/[23]*; do ( cd $d; for f in ../../src/*.[ch] ../../src/makefile; do if [ ! -f `basename $f` ]; then echo "# linking to" $f "in" $d; ln -s $f .; fi; done; echo ""; echo "# building library in" $d; make -k>makelog 2>&1; cat makelog; ) done
# linking to ../../src/udfdrag.c in aix43/2d
# linking to ../../src/makefile in aix43/2d
# building library in aix43/2d
make: 1254-004 The error code from the last command is 2.
I have no idea what does this error code mean. Do you?
Old   March 25, 2003, 22:52
hedonist
When I copy the example file of DEFINE_ADJUST in UDF manual p 4-5 into my udf_file.c, it compiles successfully. However, when I copy the DEFINE_DPM_DRAG example in p 4-75 into the same file, the error message always says:
Anyone knows why? And anyone tried to use DEFINE_DPM_DRAG ?
Old   March 26, 2003, 14:55
Alex Munoz
Hello
I know what it is happening
I think you are using Fluent 6 but the code that you copy is made for Fluent 5
Make sure that you copy a source code made for the Fluent that you are using
For instance in Fluent 6 you write Get Domain include udf.h
whereas in FLUENT 5 you write Domain include udf.h include dpm.h include sg.h
Therefore, make sure that you know the difference between each version when you write your code
Best Regards
Alex
Old   March 26, 2003, 18:38
hedonist
You are right, Alex! I found that I need to add
#include "dpm.h"
in order to use the example file from the UDF manual I have. Thanks a lot.
Old   March 26, 2003, 19:33
Alex Munoz
Hi hedonist!
I know it!
Now you can send me a present, this compiling problem could take you week to found it!
Anyway, now you can practice your nick name "hedonist"
Regards
Alex
Old   March 26, 2003, 22:45
hedonist
Present to Alex:
O
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
I want to use pressure of 1 face in udf that compiled on other face iman_1844 Fluent UDF and Scheme Programming 3 June 10, 2010 12:55
Why udf can not be compiled in my pc? Xinqiang FLUENT 0 June 10, 2009 14:32
difference between udf compiled and udf interprete chandra sekhar FLUENT 2 April 11, 2006 00:04
how to quit compiled or interprited UDF tian FLUENT 0 April 8, 2003 23:53
