Pressure drop
Old   March 26, 2003, 23:09
Default Pressure drop
Senthilkumar
In the flowdomain we are not able to get the overall pressure drop as compared with experimental results.
To get pressure drop closely with experimentalvalues, what should be the reasonable y+ value near the walls. And which Turbulence model is the best suited? We are running cold flow through the combustor of an GAs turbine, which consists of an nozzle and liner set up.
pressure drop in the pipe mike.mm FLUENT 6 February 7, 2011 10:31
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Total and static pressure drop Janakiram Siemens 1 February 8, 2009 01:32
Pressure Drop at entrance of a rotor-stator. Resnick Main CFD Forum 0 November 20, 2007 14:50
Periodic boundaries and pressure drop MatejK CFX 2 July 12, 2005 04:47
