June 17, 2008, 05:56 |
Inclination angle and counter current flow
Hai all,
I am a beginner with Fluent. I am starting the project with some inclination angle in it. 1. Can someone tell me How to implement inclination angle into the model. 2. Is there any tutorials explaining to work on the counter current flow ? Any tips How to implement counter current flow in Fluent. Thanks. Prabha. |
June 18, 2008, 02:30 |
Re: Inclination angle and counter current flow
One way to look at he problem is to modify the grid to have the inclination, so during the development of grid itself u will see that it is inclined to the angle
the other way is u know the inclination angle if suppose u are giving the velocity as boundary condition u specify the component of velocity in that direction and u get the same effect |
June 18, 2008, 04:03 |
Thank you Ramesh. I will try it out.
April 11, 2011, 21:00 |
Fredy Cabrales
Rep Power: 16 |
Hi Praba,
were you able to set up the boundary conditions for your simulation? I am having the same problem as you. I really appreciate your help. |
Counter flow HX | moh | FLUENT | 0 | January 14, 2009 02:53 |
Modelling a gaz-liquid counter current flow? | Arou | FLUENT | 0 | March 9, 2008 06:12 |
Supersonic flow past a wedge with counter flow | Mahesh Bailakanavar | FLUENT | 0 | February 14, 2008 00:21 |
Turbulent counter-flow | cristion | FLUENT | 5 | October 7, 2005 09:47 |
angle of inclination in vof | kiran | FLUENT | 2 | July 19, 2005 16:32 |
