Variable velcity at inlet
Old   April 7, 2003, 11:18
Default Variable velcity at inlet
John
Hi:
I met a problem in calculating the airflow pass the building. The inlet velocity varies with the height from the groud. It is not a constant. How can I cope with this problem?
Thanks John
Old   April 7, 2003, 11:34
Default Re: Variable velcity at inlet
mateus
Hi! You can find a good example with explanations in Fluent UDF domentation. You should write UDF which looks something like this (with other velocity function):
include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[1];
F_PROFILE(f, thread, position) = 20. - y*y/(.0745*.0745)*20.;
} end_f_loop(f, thread) }
GOOD LUCK MATEUS
Pulsating flow with non-reflective inlet boundary cc1000 CFX 6 April 27, 2009 08:10
variable pressure at inlet boundary Stephanie Siemens 3 August 23, 2008 06:04
Problems with Inlet species San24 Siemens 1 May 7, 2008 06:29
How to extract Cp values at inlet tangd OpenFOAM Running, Solving & CFD 8 August 14, 2006 03:17
transitional inlet boundary condition kamp CFX 1 June 21, 2006 11:08
