Boundary Conditions for Bubble Column
Old   April 14, 2003, 01:50
Default Boundary Conditions for Bubble Column
cfd-novice
Dear all,
I am trying to model a Bubble Column. Just to begin with, at the bottom plate in a cylindrical column, I have made some holes to act as sparger holes, and have used it as "velocity inlet" for the gas phase. The rest of the bottom plate has been defined as "outflow", intending to use it as drainout of the water phase. For the top plate, similarly, I have made some holes to act as water inlet, and have used it as "velocity inlet" for the liquid phase. The rest of the top plate has been defined as "outflow", intending to use it as vent for the air. The problem does not converge, and also while checking results at any intermediate iteration, no movement of fluid can even be seen inside the column. Next I tried to use only single phase (air) for both inlets, and then also the problem does not converge. It seems the boundary conditions are not properly defined. Please suggest me a remedy.
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
