Gravity, and static pressure
Old   April 22, 2003, 01:45
Default Gravity, and static pressure
cfd-novice
Dear all. While modeling a tall vertical column (height in the positive y direction), I have defined Gravitational acceleration as X (0 m/s2) and Y (-9.806 m/s2). For a bubble column, the static pressure contours are showing increase as we go up the cloumn from the bottom. But isn't static pressure supposed to show increase as we go down the column? Where am I wrong?
Old   April 24, 2003, 19:35
Default Re: Gravity, and static pressure
Suresh Balasubramanian
I used to have a similar problem when I modeled effect of gravity in various flow problems.
Have you turned on the specified operating density in Operating conditions panel? Change the default density to zero and you will probably get to see the static pressure increasing as you go to the bottom.
There is some bug in Fluent which I don't fully understand that unless you turn on the specified operating density you don't see the effect of gravity on static pressure.
Hope my suggestion helps you.
Regards, Suresh
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
How can i get the static pressure in a simple problem? tofighi FLUENT 1 September 27, 2011 10:45
Negative pressure in Eulerial multiphase model hongyingli FLUENT 0 September 5, 2011 05:29
negative static pressure Selo melo FLUENT 5 December 18, 2006 09:30
static pressure in non-inertial frames sam Main CFD Forum 0 April 26, 2004 11:01
