Non-cooper-able volume, please help
Old   May 21, 2003, 21:09
Default Non-cooper-able volume, please help
Riham
Hi everybody,
I wanna mesh a 3D volume (brick with two openings ) like the one in the modeling guide, figure 3-64 (c), Gambit documentation. the only difference is that I only have circle faces (holes) instead of cylinders.
They say that it is a non-cooper-able volume and to make it cooper-able, I should first split the upper and lower rectangular source face (figure 3-65)
I tried to make a virtual face split but it gaves me an error message like (edge endpoints do not belong to boundary face).
have anyone encounterd this problem ?
sorry for being long
Thank you very much in advance
Old   May 22, 2003, 06:25
Default Re: Non-cooper-able volume, please help
zxaar
well, just try this : while messhing select try ignore size function.
Old   May 22, 2003, 20:13
Riham
Hi zxaar,
Thank you very much for your help, but actually I get this error message before meshing.
cause I have to split the source faces before meshing them as far as what I understood from the documentation.
the exact message is: can't split face (face.1) with edge (v_edge.17) whose end vertices are not face boundary.
by the way do you know how to imprint the source faces before meshing them according to the cooper algorithm?
I am really confused, I am still beginner
Thanx
Old   May 23, 2003, 05:25
zxaar
do one thing ... send me the .jou file on zxaar@yahoo.com
so that i will mesh it and send u ..then will explain what was the trouble.
Old   May 26, 2003, 10:58
zxaar
hello i have sent you the mesh(jou actually) file, that day u sent me the jou file.
since u r on hotmail my message might have gone into ur junk folder please check that , it stays in junk folder for 7 days. thanks
Old   May 26, 2003, 12:57
Riham
Hi xzaar,
I have just run it, I am trying to understand the procedure you followed.
Thank you very much
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
