45 degree pipes
Old   June 10, 2003, 06:31
Default 45 degree pipes
Amir Habibdoost
We have two pipes that join to each other by degree of 45. the fluid in two pipes is same.Which method you suggest to solve the problem for swirl flow that happens after mixturing of flow of two pipes??
Thank You.
Old   June 10, 2003, 12:40
Default Re: 45 degree pipes
Alex Munoz
Hi
I sugguest that you read the paper of Dr Kumar Vinod and Pavithran S (Fluent consultants). Turbulent flow in two dimentional U-ducts a computational study.
All the your questions has been answers on this paper!!
Regards
Alex Munoz
Connect two pipes with different space stap CFDDmitry Main CFD Forum 0 May 19, 2011 07:24
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 08:48
360 Degree Geometry csedwar OpenFOAM Running, Solving & CFD 0 February 21, 2009 21:35
model of pipes inside pipe carmen FLUENT 0 January 22, 2009 09:27
cylindrical pipes Ben Siemens 4 June 16, 2004 11:25
