User defined rotational velocity in FLUENT
Old   June 10, 2003, 04:39
Default User defined rotational velocity in FLUENT
Abhinav
HI
I have to give a user defined rotational velocity to rotate a cone in FLUENT. But I find ( in the menu )that only a constant velocity can be given.....plzzz help me out on this! Thanx
Old   June 10, 2003, 08:31
Default Re: User defined rotational velocity in FLUENT
Christian
You have to write an udf, use define_profile to define the velocity.... there is an example in the udf manuel.
Christian
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
User Defined Profiles, Swirl, Velocity Inlet saurus FLUENT 0 January 26, 2011 15:35
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
user defined turbulence model manuutin STAR-CD 5 October 14, 2009 05:29
About Particle velocity of DPM in Fluent? long zhengwei FLUENT 0 March 13, 2009 04:02
