June 18, 2003, 09:21 |
ideal-gas setup
blank
I have a problem with the choice of the parameters of the ideal-gas for the study of supersonic-hypersonic external a comprimibile flow 3D. My choices have been: Density --> ideal-gas Cp --> constant Thermal conducivity --> constant Viscosity --> sutherland (three coefficent method) Molecular wheight -- >constant I would want hopes if the choices for the Cp and the Thermal Conducivity are adapted to my case thanks in advance payment |
June 22, 2003, 07:10 |
Re: ideal-gas setup
Why can't you try kinetic theory for Cp and K. Don't forget to specify Degree of freedom if you are using kinetic theory for Cp. Rahul
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Help!! calculate gas density by ideal gas law | Mahe | Phoenics | 1 | January 26, 2010 03:57 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
