display - dimensions
Old   June 11, 2003, 10:05
Default display - dimensions
rookie
Hello All,
My computational domain is so slim: the ratio of length to width is over 25. You can see the display problem -- Is there a way to zoom in one-direction, while zoom out the other direction?
Thank you!
rookie.
Old   June 25, 2003, 01:09
Default Re: display - dimensions
Alamgir
Just rotate the geometry about vertical axis about 45 degrees and then use view and camera option to get the geometry close to u and zoom it as much as the screen supports.
Alamgir
Old   June 25, 2003, 21:28
rookie
Thanks,Alamgir. It works! Great!!
Rookie
problems with Fluent display windows chris FLUENT 3 January 7, 2016 10:44
Incompatible dimensions.... Amiga500 OpenFOAM Running, Solving & CFD 13 June 1, 2012 07:20
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 04:23
free surface display carno Siemens 4 October 7, 2005 01:03
Gambit - display dimensions osh FLUENT 4 August 22, 2005 04:33
