retrieve material density
Old   June 19, 2003, 15:39
Default retrieve material density
rookie
Hello All,
Does anyone know the marco which could retrieve material density? something like MATERIAL_PROP(sp, PROP_mwi) for molecular weight?
Thank you all in advance!
Rooike
Old   June 27, 2003, 04:36
Default Re: retrieve material density
Mcgregor
Hi Rooike,
If you want to retrieve density data just to annalyse the results then you can go to the solve/monitors/surface of solve/monitors/ volume sections.
This way you can report the maximum, minimum or average density on a face or volume node.
Hope this is of some help.
If you need the values for inclusion in a UDF, you can do this too, but it is a bit more difficult. You may have to store the values in User Defined memory
Mc
Old   June 30, 2003, 11:12
rookie
Thank you! Mcgregor. I figured out the MARCO--it is MATERIAL_PROP(sp, PROP_rho). However, your solution helped me other problems.
Rookie
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Warning 097- AB Siemens 6 November 15, 2004 04:41
