UDF
Old   July 15, 2003, 21:42
Default UDF
wang
Hello all:
I use the UDF try to get the previous time step temperatur by C_T_M1(c,t) for unsteady flow simulation. But it cann't run normally. If i change the C_T_M1(c,t) to C_U_M1(c,t), there are no any problem. Clould anyone tell me hot to get the previous time Temperature? The bellow is the udf code:
#include "udf.h" #define CON 0.5 #define SL 1.0
DEFINE_SOURCE(cell_source,c, t, dS, eqn) { float source; float temp; float t1; float t0; float dt; float density; float curr_ts;
curr_ts = RP_Get_Real("flow-time"); dt=RP_Get_Real("physical-time-step");
if (curr_ts>0.1) { t0=C_T(c,t); t1=C_T_M1(c,t); density=C_R(c,t); printf("%15.7f%15.7f%15.7f\n",t1,t0,dt); source = -CON*SL*density*t1/dt; dS[eqn] = -CON*SL*density; }
return source; }
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
