a problem with UDF
Old   July 24, 2003, 15:48
Default a problem with UDF
Baz
Hi, I have a problem with interpreted UDF . I wrote a simple initialization function for density gradient and after I initialize the solution, I can see contours of variable density. But, even after one iteration the density changes into constant. Why? Thank you for help.
Old   July 24, 2003, 22:56
Default Re: a problem with UDF
ccc
hi, I have similar problems. if anyone know, think in advance.
Old   July 25, 2003, 05:12
Ale
perhaps I didn't get the point, but that's what I think: If you initialize a variable, however you do that, you give an initial approximation of the solution. If your model doesn't change the density during the calculation, and you've set a constant value for density in the Materials panel, at the second iteration you'll get that value in all the domain.
You should probably write a DEFINE_PROPERTY macro in your UDF, defining the law of change of your density during the simulation.
Good luck,
Ale
Old   July 25, 2003, 09:53
ap
I agree with Ale.
If you keep constant the density in Material properties, FLUENT will use your initialization value just to compute the first iteration.
Hi
ap
Old   July 26, 2003, 18:39
Lola
I thought after 'first iteration', the solution is NOT 'converged'. Why would I bother checking any solution in some intermediate iterations??
Old   July 27, 2003, 19:22
ap
I'm not telling the solution is converged after the first iteration.
I just say that if you initialize a density value, but you keep constant density in the material properties, FLUENT will use the value specified there (Material properties) to do all computation except for the first iteration.
Hi
ap
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 09:58
