x-y Plot from more than one data file
Old   July 31, 2003, 00:20
Default x-y Plot from more than one data file
solomon
I would like to make multiple plots on a single x-y graph of results from about four different simulations. How is it possible to do this in fluent? To my knowledge it seems fluent only allows to open one case and data file at a time and plot them separately.
Old   July 31, 2003, 04:54
Default Re: x-y Plot from more than one data file
Ale
You can save an xy file with your data for each simulation (i.e. each case and data file), and then load all the xy files in Fluent and make a single plot with all your curves (there is a 'load file..' button in the plot panel). I hope this helps.
Regards,
Ale
Old   July 31, 2003, 05:46
Mcgregor
If you go to plot/file and then click the add tab, then you can add as many output files as you want. Then when you click plot on the form, they are all displayed together
Mc
Old   July 31, 2003, 15:18
Default Thank You guys
solomon
Thank You
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Extract data we want from Techplot to a data file vetnav Main CFD Forum 0 July 28, 2010 20:17
Urgent : Saving the plot data to a file ck1973 FLUENT 1 July 14, 2006 07:44
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
