Unrealistic results
Old   July 30, 2003, 11:12
Default Unrealistic results
Manuel
Hello, I'm currently carrying out a simulation of a centrifugal water pump and results obtained so far for the head coefficient are far from realistic (about half the value of the experimental data). Data used so far: -ratational reference frame for blade passage -tethraedal mesh -200 000 cells -second order upwind -second order pressure scheme -convergence criterion:1*10-5 -k-epsilon turbulence model -under relaxation factors lowered to 0.2 for pressure and 0.5 for momentum,k and epsilon -inlet bc velocity, constant at the pipe inlet -outlet bc constant pressure at vaneless diffuser, 0 gauge
If anyone has any suggestion about what I could try or check, it would be more than welcome, thanks a lot
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
How to plot a function over a time period? Cirion0000 CFX 4 July 18, 2009 12:48
how to view the complete results shokry FLOW-3D 5 February 3, 2009 13:56
Airfoil y+ Results Query asd Main CFD Forum 1 June 22, 2007 08:02
