August 12, 2003, 03:29 |
help!! XY plot
Dear senior:
In the 3D model,I cuted a plane (2D) and I wanted to plot pressure variable along some line. Fluent postprocessor Could do that by XY Plot? THKS |
August 12, 2003, 05:22 |
Re: help!! XY plot
Yes, Look at number 20 tutorial on postprocessing step 11. XY plots, it does exactly that.
August 12, 2003, 05:49 |
Re: help!! XY plot
Thks eric:
that tutorial is made a straight line, if I want a curve line could do that? |
August 13, 2003, 03:34 |
Re: help!! XY plot
Hi, if you want curse instead of straight you can create an isoclip with a very thin thickness or use the option quadric. You can create circle, power function, ellipse ect ect ect . good luck thomas
Plot on a curve | Monica | FLUENT | 1 | July 11, 2012 00:24 |
A girl fail to plot velocity profile when mesh changes + Wall function | asherah | STAR-CCM+ | 0 | February 19, 2010 17:45 |
Transfer low-res graphic file plot to excel plot | quarkz | Main CFD Forum | 3 | April 9, 2009 13:54 |
graph plot | anindya | Main CFD Forum | 2 | September 17, 2003 12:00 |
why can't I plot Y+ value? | Jiaying Xu | Siemens | 2 | August 18, 2001 10:56 |
