ERROR?
Old   August 18, 2003, 07:33
Default ERROR?
zahid
Welcome to Fluent 6.0.12
Copyright 2001 Fluent Inc.
All Rights Reserved
Loading "c:\fluent.inc\fluent6.0\lib\fl_s112.dmp" Done. Could not check out fluent: Invalid returned data from license server Feature: fluent Hostname: Che_nt License path: c:\fluent.inc\license\license.dat; FLEXlm error: -12,122 For further information, refer to the FLEXlm End User Manual, available at "www.globetrotter.com".
Hit return to exit.
Old   August 18, 2003, 11:13
Default Re: ERROR?
ap
Your license file (license.dat) has some problem, and the license server doesn't allow FLUENT to start.
Old   August 18, 2003, 12:13
Default Re: ERROR?
Zahid
the same (license.dat) is working fine with other PCs.
Old   August 18, 2003, 13:01
Default Re: ERROR?
cfdweirdo
You may have exceeded your max number of open Fluent processes.
Ask someone to shut down one of their sessions and try starting up Fluent again.
Old   August 19, 2003, 03:10
Default Re: ERROR?
Zahid
When all are in use then this happens. =======================================
All Rights Reserved
Current fluent usage: 1. Guest@che-ws-04 Mon Aug 18 19:09 che-ws-04 2. Guest@che-ws-04 Tue Aug 19 10:13 che-ws-04 3. Guest@che-ws-04 Tue Aug 19 10:13 che-ws-04 4. Guest@che-ws-04 Tue Aug 19 10:13 che-ws-04 5. Guest@che-ws-04 Tue Aug 19 10:13 che-ws-04 6. Guest@che-ws-04 Tue Aug 19 10:13 che-ws-04 7. Guest@che-ws-04 Tue Aug 19 10:13 che-ws-04 8. Guest@che-ws-04 Tue Aug 19 10:13 che-ws-04 9. Guest@che-ws-04 Tue Aug 19 10:13 che-ws-04 10. Guest@che-ws-04 Tue Aug 19 10:13 che-ws-04 11. Guest@che-ws-04 Tue Aug 19 10:14 che-ws-04 12. Guest@che-ws-04 Tue Aug 19 10:14 che-ws-04 13. Guest@che-ws-04 Tue Aug 19 10:14 che-ws-04 14. Guest@che-ws-04 Tue Aug 19 10:14 che-ws-04 15. Guest@che-ws-04 Tue Aug 19 10:14 che-ws-04 16. Guest@che-ws-04 Tue Aug 19 10:14 che-ws-04 17. Guest@che-ws-04 Tue Aug 19 10:14 che-ws-04 18. Guest@che-ws-04 Tue Aug 19 10:14 che-ws-04 19. Guest@che-ws-04 Tue Aug 19 10:15 che-ws-04 20. Guest@che-ws-04 Tue Aug 19 10:15 che-ws-04 License for fluent expires 27-oct-2003. All licenses for fluent are currently in use.
Hit return to exit. ====================================== That PC is still, all the time, giving the above mentioned (AT THE START)message.
Old   August 19, 2003, 08:38
Default Re: ERROR?
cfdweirdo
It says right at the end that all of the Fluent licenses are in use. You only get a certain number of licenses per your purchase agreement. If all of the available licenses are being used, then you cannot open a new session. You need to ask some of the other users to shut down their active sessions, so you can open one.
Do all of those sessions belong to you? Are you the only user? Do you have any other sessions open?
If your answers are yes, yes, no. Then you may have some orphan processes running which are gobbling up your available licenses and you will need to terminate them.
Old   August 19, 2003, 11:37
Default Re: ERROR?
Zahid
Thanks. i have shown that when all licenses are in use then the message will be like that. "all ... are in use" so ur answer on Mon 18 Aug 2003, 11:01 a.m was denyed by that ==================================== i have still the ERROR on the PC which i have mentioned on Mon, 18 Aug 2003, 5:33 a.m ============ thanks again
Old   August 19, 2003, 12:27
Default Re: ERROR?
Mark
Hi Zahid,
I had exactly the same problem. It turned out there was a spyware program blocking my port. This stopped my work for weeks because fluent couldn't figure this out!!
you must get your hands on an ad removal package like ad-watch from lavasoft. Try download.com, I'm sure you can get a spy removal program from there.
Hope this helps , Mark.
Old   August 20, 2003, 04:57
Default Re: ERROR?
jieremy
U must start your FLEXM server. IF you do not define the FLEXM server to be started automaticly when the system is started,you must start the FLEXM server manually.
Old   August 20, 2003, 11:08
Default Re: ERROR?
Zahid
it is started
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
