can fluent(multiphase model) solve evaporation
Old   August 26, 2003, 09:16
Default can fluent(multiphase model) solve evaporation
prasanth
hi, my problem is evaporation of liq. H2 in a closed cylindrical tank that is filled upto some 80% or 60% level,due to application of constant heat flux on the tank. I havent seen any application for this problem in Fluent, even in manual, there is no example. I am presently using mixture model with UDF for source terms of mass and energy into liquid,vapor continuity equn and energy equn. it showing some rate of evaporation as there is decrease in quantity of liq. But i am still suspicious of my modeling, as there is no bench mark problem for this kind. Is there any other possiblity in Fluent or any other package..or the any modification to present problem.
thanks, regards, Prasanth
Old   August 26, 2003, 10:59
Default Re: can fluent(multiphase model) solve evaporation
mateus
Hi!
I'm almolst shure that I've seen something like that on Fluent homepage, but I can't find it now. Anyways I think you're on the right track, concerning, models and udfs that you use.
Good luck
MATEUS
Old   August 26, 2003, 11:03
prasanth
I hope too... thanks!!!!
Old   August 27, 2003, 14:35
ap
The application you're looking for should be here:
http://www.fluent.com/software/fluen...multiphase.htm
Old   August 28, 2003, 02:50
mateus
Hi!
Yes that was it....
MATEUS
Old   August 29, 2003, 09:08
prasanth
That application is pure boiling...mine is simple evaporation from free surface.any way thanks for ur response.
Old   September 9, 2003, 09:59
prasanth
I observed one defect in my program, even before the liquid is reaching the saturation temperature at the interface there is evaporation taking place. i provided the condition for sat. temp. what could be the reason? prasanth
Old   May 8, 2010, 15:54
Mahdi Hosseinali
anishtain4 is on a distinguished road
is there a feature for this subject in fluent 6.2? modeling evaporation I mean.
anishtain4 is offline   Reply With Quote
Old   June 15, 2010, 13:54
teo wei how
Lightning is on a distinguished road
bro...can u teach me or pass me ur udf file for the evaporation process ? i'm currently doing that as well for my final year project ....my email is weihow_8@hotmail.com i need serious help here >.<
Lightning is offline   Reply With Quote
Old   June 16, 2010, 06:27
Mahdi Hosseinali
I'm sorry but as long as I know there is no simple way, for my work it was easier to do several repeatedly calculations than find a solution in fluent.
Can I use turbulent model to solve a laminar flow? nikhil FLUENT 5 February 1, 2011 10:42
Half laminar and turbulent model trying to solve Andrew Clarke FLUENT 5 May 19, 2008 13:40
Mixture model - water droplet + air - EVAPORATION bohis FLUENT 4 January 25, 2008 11:04
Droplet evaporation model (Dukowicz) student Main CFD Forum 0 January 25, 2007 04:25
Seawater evaporation model Gerardo Trejo FLUENT 0 September 5, 2005 20:33
