turbulent viscosity limited to viscosity ratio...
Like Tree25Likes
  • 19 Post By ap
  • 1 Post By RodriguezFatz
  • 1 Post By Marion
  • 3 Post By davidwilcox
Old   August 29, 2003, 16:12
Default turbulent viscosity limited to viscosity ratio...
frank
of 1e5 in 140 cells?
i am not sure what this means but this was a message fluent gave me when i ran a simulation for drag using the k-e model. reynolds number is about 30 million. if you have ideas please let me know.
Frank
Old   August 29, 2003, 19:42
Default Re: turbulent viscosity limited to viscosity ratio
ap
The turbulent viscosity ratio is defined as following:
turbulent viscosity
laminar viscosity
FLUENT limits this ratio to a fixed value in order to obtain a stable solution.
Usually this limitation happens when you use a poor quality grid, or you specify wrong boundary conditions for turbulence variables.
Plot a contour of turbulent viscosity ratio. You'll identify where the problem happens. Try to refine the grid there. Also check turbulence boundary conditions.
Hi
ap
Old   September 2, 2003, 20:59
frank
thanks i found the section where the turbulent viscosity ratio is high should i refine the grid there?
frank
Old   September 2, 2003, 22:18
Lee
It happened to me in the beginning of iteration. As the solution get converging, it simply goes away.
Old   September 4, 2003, 07:13
ap
Yes. Try to refine the grid.
Also, if you use first order discretization scheme, try to switch to a higher order one.
As Lee said, it's possible that you'll have this warning message during the first iterations. If it will disappear, don't consider it as a problem.
Hi
ap
Old   September 28, 2003, 17:31
johnnyb
It happened to me too, but went away after 22 iterations. 22 is very few, but is this something I should worry about?
Old   July 10, 2009, 10:33
Ama
Ama is on a distinguished road
hi,
do you know how to refine the grids where tubulant viscosity is limited ??
when i run my program it does give me as : "viscosity ratio is limited to viscosity ratio of 100000000 in ........... cells" and also "reversed flow in ... face on outflow ...."
how can i resolve this?
Please i need your help.
Many thanks !!
Ama
Ama is offline   Reply With Quote
Old   July 9, 2012, 02:54
eng_s_sadeghi's Avatar
eng_s_sadeghi is on a distinguished road
Originally Posted by Ama View Post
hi,
Many thanks !!
Ama
It is better to correct your mesh in gambit, else you can refine it in fluent, refine the places which turbulence is higher than a value.
Saeed Sadeghi
Ansys Fluent CFD Consultant
eng_s_sadeghi is offline   Reply With Quote
Old   July 9, 2012, 09:34
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Originally Posted by johnnyb
;108196
No, don't worry. If it vanishes during calculation, it is just due to a bad initial guess. This is not a problem for your final results.
RodriguezFatz is offline   Reply With Quote
Old   July 9, 2012, 11:25
cfd seeker is on a distinguished road
any idea how to set turbulence boundary conditions?
cfd seeker is offline   Reply With Quote
Old   July 10, 2012, 04:08
Philipp
Once you chose a turbulence model, new checkboxes and input fields become available in the boundary conditions of your inlets and outlets. Here You can set the turbulence boundary conditions as well.
anijg05 likes this.
Old   July 14, 2012, 01:01
shoeb khan
shk12345 is on a distinguished road
I want to know how to and when to use which turbulence models.
Kindly give your comments.
Regards
shk
shk12345 is offline   Reply With Quote
Old   July 16, 2012, 03:09
Philipp
Regards
shk
Your question is much too open to be answered in a forum. I don't think anybody will have the patience to give you an adequate answer. I strongly recommend to read several books about that.
maridani likes this.
Old   July 16, 2012, 03:51
shoeb khan
Suggest me name of some books
Regards
shk
Old   July 16, 2012, 04:06
Philipp
Regards
shk
All books I have only have small chapters about exactly that topic. But this one is really one of the best CFD books:
"An Introduction to Computational Fluid Dynamics - The Finite Volume Method", H K Versteeg, W Malalasekera
with some pros and cons about important models. (But again, just a small chapter)
I got several other superb books, unfortunately for You: They are on German...
Also this paper:
"Hybrid LES/RANS methods for the simulation of turbulent flows", Jochen Fr๖hlich, Dominic von Terzi
is brilliant - if You are interested in unsteady turbulence modelling.
What kind of flow are You interested in?
Old   July 16, 2012, 04:11
Marion
Marion is on a distinguished road
On CFD online you have a section called "books" and a subsection "turbulence" http://www.cfd-online.com/Books/brow...?category_id=4
That's where I found the reference to "Turbulence modeling for CFD" - I find it very interesting, even though I havent finished it yet :-)
Marion.
tbraun84 likes this.
Marion is offline   Reply With Quote
Old   July 16, 2012, 04:14
shoeb khan
Originally Posted by Marion View Post
Marion.
Thanks for the reference.
Old   March 31, 2013, 14:04
  #18
D_SH is on a distinguished road
Hello, my friends!
I model ispernie water droplets in contact with the flow of highthermal (steam). After several iterations of the message ' turbulent viscosity limited to viscosity ratio ' Solver takes off. The reason?
Eulerian model and turbulence to the k-omega.
D_SH is offline   Reply With Quote
Old   April 10, 2015, 14:33
shivakumar is on a distinguished road
Can anyone explain me about free stream laminar and free stream turbulent viscosity?
shivakumar is offline   Reply With Quote
Old   December 15, 2015, 22:54
david
davidwilcox is on a distinguished road
Shivakumar,
In the Navier-Stokes equation, you do not see a turbulent viscosity. It comes about when you do a Reynolds Average on the N.S equations. This is to account for the Reynolds stresses which is a product of the advection terms. The eddy viscosity is also used in the formulation of the gradient diffusion term to account for the triple correlations and pressure diffusion. NOTE: these are modelled terms and not explicit. So coming back to your question, to what is laminar and what is turbulent viscosity, the answer is this laminar viscosity is just the constant of the diffusion term in the N.S equation while turbulent viscosity is the "constant" used in RANS to model the reynolds stresses, etc. Hope this helps
davidwilcox is offline   Reply With Quote
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 511831 cells ZQWY FLUENT 18 June 8, 2023 11:36
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 11:04
Turbulent viscosity limited to viscosity ratio of 1.0000000e+5 eespi002 FLUENT 3 June 30, 2009 13:24
Turbulent viscosity limited to viscosity ratio... Cyril FLUENT 8 February 7, 2006 20:34
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
