error in using UDF for specifying drag coefficient
Old   September 17, 2003, 05:53
Default error in using UDF for specifying drag coefficient
Shekhar Jain
i am getting an error: Error: Set_Property: null user-defined-function name Error Object: ()
while setting the UDF(interpreted) for specifying the drag coefficient in Eulerian multiphase model using the macro DEFINE_EXCHANGE_PROPERTY.
Old   September 17, 2003, 07:24
Default Re: error in using UDF for specifying drag coeffic
Ale
Have you defined a name (the first argument of the macro) for your UDF?
DEFINE_EXCHANGE_PROPERTY (name, c, mixture_thread, second_column_phase_index, first_column_phase_index)
Good luck,
Ale
Old   September 17, 2003, 08:34
ap
I had the same error using interpreted UDF. I "solved" it doing this way:
- Start FLUENT and load the mesh file, then the UDF (Define -> User Defined -> Functions -> Interpreted).
- Set up the case. When you choose your drag factor, you'll obtain the error. Ignore it.
- Save the case file and exit FLUENT.
- Open FLUENT again and load the case file. FLUENT automatically compiles the UDF.
- Set your drag factor again. Now you shouldn't see the error message.
Hi
ap
Old   September 18, 2003, 03:48
Shekhar Jain
Thank you for your reply. I have defined a name for my UDF as the first argument to the DEFINE macro.
Old   September 18, 2003, 03:50
Shekhar Jain
Hi ap, Thnak you for your reply. It indeed worked thanks a lot.
Drag Coefficient for Ellipse Form (2D) Ketut Utama Main CFD Forum 8 December 11, 2014 11:03
Problem with UDF (Drag model) understate FLUENT 0 January 4, 2011 05:01
Solidification drag coefficient atulverma FLOW-3D 1 May 14, 2009 09:24
drag coefficient & drag force abhishek.mnit FLUENT 0 April 29, 2009 23:48
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 12:19
