September 26, 2003, 17:52 |
UDF source file
I defined several UDF (DEFINE_ADJUST,DEFINE_PROPERTY,DEFINE_SOURCE) in one source files. However,after i complied the source file and hook into FLUENT, i can only see one UDF that is available in FLUENT. Why couldn't i see others UDF in FLUENT?
September 29, 2003, 04:51 |
Re: UDF source file
hi,
canīt answer. can you post your source? then it could be easier to understand... |
September 29, 2003, 10:42 |
Re: UDF source file
Following is source terms DEFINE_PROPERTY(cell_density,c,t) {
real density; density=2967.7679; return density; } DEFINE_SR_RATE(my_rate,f,t,r,mw,yi,rr) { *rr=1.03643e-4; } DEFINE_SOURCE(species_K,c,t,dS,eqn) { real K_source; K_source=C_UDSI(c,t,14)+C_UDSI(c,t,15); dS[eqn]=0.0; return K_source; } Please take a look. I don't know if there are some problems with C compiler in our systems. I guess there are some confliction between different edition. |
September 29, 2003, 11:53 |
Re: UDF source file
it is working, but only with: #include "udf.h" at the beginning ...
tecio compilation errors in latest 1.6.x | rsamuel | OpenFOAM Bugs | 2 | June 25, 2021 08:10 |
polynomial thermophysical properties II | sebastian | OpenFOAM Running, Solving & CFD | 54 | November 21, 2019 07:12 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
