Constant wall heat flux with uniform temperature
Old   September 23, 2003, 12:36
Default Constant wall heat flux with uniform temperature
Jake
I am using Fluent to model heat transfer for flow inside a channel with constant heat flux boundary condition. Is there a way to impose a uniform wall temperature around the periphery at the same time, i.e. H1 boundary condition? I have tried giving the wall material a very high thermal conductivity (1e+20) but there is still significant temperature variation in the wall periphery.
Any pointer would be greatly appreciated. Thanks in advance.
Jake
Old   September 29, 2003, 04:40
Default Re: Constant wall heat flux with uniform temperatu
Martin
hi,
have you tried to write an udf? i donīt know whether it works but with DEFINE_HEAT_FLUX it could be possible... take a look in the manual...
Old   September 29, 2003, 11:34
Jake
Hi Martin, I have not tried writting an udf. Will try that. Thanks for the pointer. Appreciate that. Jake
problem with constant wall heat flux openfoam1 OpenFOAM 6 January 13, 2019 08:18
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 11:49
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
assign both heat flux and temperature on wall qwerty753 FLUENT 2 July 14, 2010 08:09
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
