wall b.c
Old   October 6, 2003, 10:45
Default wall b.c
eric
Hi all,
I want to know how to apply a temperature at a wall. The wall temperature changes as the flow proceeds down stream, yet fluent will only let me apply a constant wall temperature.
By applying a constant temperature along the wall am i effecting the heat transfer rate of the flow?
Is there a way of applying a wall temperature so that it changes with the flow, i.e. a temperature dependent wall condition?
Regards,
Eric
Old   October 7, 2003, 11:28
Default Re: wall b.c
Prabu Parthasarathy
Eric,
You should be able to define a UDF in FLUENT and once it is defined, FLUENT will automatically bring the UDF name as part of the set Temperature Menu. If you don't define anything, you will only see Constant but once you have a UDF, you will see the name listed also.
One of the UDF tutorials will help you define this.
Good luck.
Prabu
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
Rigid wall B.C in discontinuous Galerkin method(DG jinwon park Main CFD Forum 0 March 25, 2008 07:33
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 02:05
Wall functions? Pr Main CFD Forum 7 April 8, 2004 06:15
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
