Cavitation (divergence)
Old   October 21, 2003, 04:13
Default Cavitation (divergence)
ROOZBEH
Hi; By the way I have to work with Fluent6.0.12 . Because your suggestion I increase velocity from 0 to 13m/s (2,4,6,8,10,10.5,11,11.5,12,12.5,13 m/s). But when cavitation occure, even with void fraction of .0001, the solution go to instability. I think this is caused by VOF equation at first. I have no way, only the relaxation number of .001 for vaporization mass and minimum of .1 for the others, remove this problem! I ran a case with this setting and got approximatly good results. But the time of cavity bubble development and dettachment is very high i.e. a low shedding frequency. Note that I do not use turbulence modification. I think my case has some problem: - low grid numbers near first cavity bubbles(I use 30000 mesh cell) - I have to modify the cavitation rate source term in the VOF eqwuation to model of "THREE-DIMENSIONAL UNSTEADY CAVITATION EFFECTS ON A SINGLE HYDROFOIL AND IN A RADIAL PUMP – MEASUREMENTS AND NUMERICAL SIMULATIONS" By: "M. Frobenius, R. Schilling R. Bachert, B. Stoffel, G. Ludwig" I am trying to provide the new version of software. Thanks.
Divergence problem for species transport model MY FLUENT 3 January 11, 2014 04:46
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Divergence in modeling cavitation around hydrofoil Mahdi FLUENT 1 December 3, 2007 05:14
Cavitation Simulation by CFD Liu, L. CFX 2 November 29, 2000 13:50
Cavitation Simulation by CFD Liu, L. Siemens 2 November 1, 2000 21:51
