UDS DIFFUSIVITY
Old   October 31, 2003, 05:33
Default UDS DIFFUSIVITY
naima
I like te difine the UDS Diffusivity with a UDF but i have some problems. so, I used the udf given by fluent :
# include "udf.h" DEFINE_DIFFUSIVITY(mean_age_diff, c, t, i) { return C_R(c,t) * 2.88e-05 + C_MU_EFF(c,t) / 0.7; }
also with this udf(fluent) ihave the same error : Error: C:\work\tt.c: line 1: parse error. I'd appreciate your help, think you
Old   October 31, 2003, 06:12
Default Re: UDS DIFFUSIVITY
thomas
Hi, This has nothing to do with your UDS. You just have certainly not well placed or simply forgotten a ';' somewhere. Check all your ';' and your parse error will disappear. Where are you from in France ? thomas
Old   November 3, 2003, 03:48
naima
In the UDF I sent , there is only one ";". I've checked it again and it doesn't work no more! Any other suggestions Thanks
Old   November 3, 2003, 04:39
thomas
Hi, You should also check everything which you make your syntax wrong like ';' ',' '('. I would suggest to put your mathematical expression between brackets '()' after the command return. Like return ( C_R(c,t)*2.88e-05+C_MU_EFF(c,t)/0.7 ); You could also declare a UDMI variable to stock this operation result and then return it. Hope this help. thomas
Old   November 3, 2003, 17:57
Devin
I believe your error is in the line
# include "udf.h"
there should be no space between # and include, also udf.h should not be in quotations it should be enclosed by <>. I would type the line exactly as it should appear, but for some reason it won't display properly.
Cheers, Devin
Old   November 4, 2003, 04:07
naima
Thanks for your suggestions, that i tried, but it doesn't work, I don't know why!!!
Old   November 4, 2003, 04:56
nounou
Dear Miss Reaaly, I don't know where is your problem, because I have the same message!!! oh my god, Does any one tried to use the same expression of naima in his station!!!
Old   November 4, 2003, 05:14
Mohamed
I tried it me also, and it gives me the same error message!!! May be because I'm a beginner with UDF. But this one seems very easy and despite of that, it doesn't work! Does any one other tried it? Mohamed
Old   November 5, 2003, 06:20
Naima
Thanks for all of you.
Finally I can interpret my UDF. I'm not sure about the raison but it seems that it was a problem of file source format (bin or ascii or informatics mystery!!). Indeed, since I've rewritten the same UDF in a C Compiler Editor, it became possible to compile it successfully.
Thanks
PEM modeling UDS diffusivity in mixture gemini FLUENT 6 August 7, 2012 07:37
What is UDS diffusivity of a self-defined material? aleisia FLUENT 0 March 5, 2011 22:08
Fluent 6.3 pemfc module, UDS diffusivity yerem3 FLUENT 0 January 19, 2010 03:10
Directional Diffusivity of UDS Source Greg Perkins FLUENT 2 September 4, 2003 03:02
UDS DIffusivity... up FLUENT 4 July 16, 2001 08:11
