Two Phase Flow
Old   November 14, 2003, 11:48
Default Two Phase Flow
Parshant Dhand
Hi there,
I wnated to know how can I set water vapor + Liquid water coming in from one boundary inlet. My Problem has two inlet and one outlet. On one inlet there is air coming in and other inlet there is water vapor with vapor fraction of 0.74 coming in. How do I model the stream with liquid water and water vapor coming in. Thanks
Parshant
Old   November 14, 2003, 12:27
Default Re: Two Phase Flow
ccc
hi, Parshant
your problem is interesting. I have one point unclear. Does the water in the water vaper will condense into the liquid water.
If the answer is FALSE, i think the simple two phase model will work. however, in the case of TRUE, it is a little complicate. The first solution came into my mind is to use udf to add or subtract a source in the continuum equation.
Old   November 14, 2003, 14:58
thomas
Hi, A multiphase model will allow you to model your system. Knowing the water-vapor bubble size, volume fraction,and the speed velocity of each phase, you can set you inlet condition. For your only air inlet just set the volume fraction to 1, velocity water =0, velocity air = ... The euler-euler model seems to be the most adequat
Thomas
Old   November 15, 2003, 02:06
mateus
Hi!
Try it with mixture model first - it works faster since it doesn't solve equations for each phase. If you don't get good results switch to Euler-Euler model...
Regards
MATEUS
Old   November 17, 2003, 11:51
thomas
Thanks for your message for Two Phase flow it was useful, can you please tell me how do I get to know the bubble size for the liquid water and water vapor for phases. Thanks Parshant -----------------------------------------------
Check publication about the same kind of simulation or problem. If you do not find that, I would suggest to use a bubble size to avoid special effect due to bubble deformation (change of drag coefficient, Lift, ....).
Hope this help. thomas
Old   November 18, 2003, 20:37
Alamgir
Parshant,
I'm also modelling such type of problem. I think Multiphase Mixture model is well enough to model. Specify each inlet separately (inlet1 and inlet2) then in Fluent choose 3 differnt materials (water vapor, water lq and air). Now which is primary phase? Set it first with knowing velocity at bc. Then set secondary phases with volume fraction and velocities.
Alamgir
Old   November 19, 2003, 08:50
nitish
i'm working on the vortex air separator using FLUENT. in case of 2 phase flow (inlet=air+20% liquid air fraction), what model can be used to get the extent of separation?
gas-liquid 2 phase flow in microchannels using VoF LyngHoo FLUENT 1 November 13, 2012 19:01
Two Phase Darcy flow with gravity -> problem Cyp OpenFOAM Programming & Development 0 November 17, 2010 07:58
two phase flow + ice phase and breaking soeren87 OpenFOAM Running, Solving & CFD 0 September 19, 2010 10:20
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 02:20
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 16:48
