November 19, 2003, 17:18 |
Natural Convection
Hi, I am trying to simulate natural convection within enclosure using Fluent, my Ra is ~10^10 (which means it is fully turbulent), I have been trying to make it work for a while. I am using the K-e model for modeling visc flow, and I am enabling the bouyance effects option, I have tried to use different radiation models, my medium is a gas with absorbtion coeff. 0.14 cm^-1, and my enclosure height is 50 cm. I made my mesh very fine, I used a BL with the first row of 0.01 cm height with growth factor of 1.2, and I have generated 40 rows, I think this should do it. Could you please help me making this simulation work, because I have been trying to make it work for a while now. If possible could you give me advice on what turbulent model to use, and if there are any options that I need to activate. Also, what do you suggest for the radiation model, and what solution schemes should I use, first order, PRESTO ... To tell the truth I will be grateful for any information you give, and I will appreciate all the details you provide. Thanks alot in advance
November 21, 2003, 16:58 |
Re: Natural Convection
That Rayleigh number isn't going to be easy. Use PRESTO and the second order upwind scheme. Try getting a solution without the radiation enabled, then re-enable it and continue the solution. Also, try increasing gravity in steps (i.e., 2 m/s^2 then 4 m/s^2 etc.) so you get a flow field set-up slowly. If all else fails, you may have to do a transient evaluation.
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
Natural Convection with heat generation | krishnachandranr | Main CFD Forum | 0 | July 28, 2009 04:22 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 04:58 |
natural convection at high Rayleigh | mauricio | FLUENT | 2 | February 23, 2005 19:43 |
Mixing By Natural Convection Processes | Greg Perkins | FLUENT | 0 | February 12, 2003 18:40 |
