Boussinesq model gives constant density
Old   February 6, 2008, 07:51
Default Boussinesq model gives constant density
daol
I'm using the Boussinesq model for density for a natural convection problem with water. I've set the operating temperature and thermal expansion coefficient for water.
The temperature difference is a maximum of 25K but still the density contours are constant throughout the entire domain. However I do get a velocity field and the only driving force I have is buoyancy so there must be some density difference. Why can't I see it in reports or contours?
Regards Ola
Old   February 13, 2008, 03:30
Default Re: Boussinesq model gives constant density
S. Gatzka
The Boussinesq-Approximation is applyed just to the buoyancy-expression in the navier-stokes-equations and not to the general density, which is treated as constant.
I experienced the same problem with a natural convection problem. The density was constant all over the area. But I got the right solution for the velocity-field. Therefore I suppose there is an other problem with your simulation.
Old   February 21, 2008, 07:51
Necmi Cevheri
If you did not use a boundary layer in the vicinity of a wall, you may not observe those density gradients. Try meshing with a boundary layer in gambit
Old   June 11, 2018, 16:54
Cyrus69 is on a distinguished road
Originally Posted by Necmi Cevheri
;148668
I have a same problem in natural convection.i've made boundary layer beside the wall as u said but that doesn't help.
Cyrus69 is offline   Reply With Quote
Old   June 12, 2018, 09:28
Andrea
Andrea1984 is on a distinguished road
The entire point of the Boussinesq approximation is to avoid the complications arising from considering the density as a temperature-dependent property.
In the approximation the density of the fluid is taken as a constant and the buoyancy effects are accounted for in the N-S with the extra term -rho_ref*g*beta*(T-Tref) where rho_ref is the (constant) density of the fluid at the reference temperature, g is the gravitational acceleration, beta is the thermal expansion coefficient and (T-T_ref) is the difference between the local and the reference temperature.
Basically it is assumed that g*(rho(T)-rho(T_ref)) ~ g*beta*rho_ref*(T-T_ref), which allows to drop the dependency of rho on the temperature. This is only reasonable if beta*(T-T_ref) << 1. If this is not the case, than you should drop the Boussinesq approximation and go with a varying density instead.
Therefore I would be surprised to see any density gradient in this case, no matter how refined is your mesh.
Andrea
Andrea1984 is offline   Reply With Quote
boussinesq approximation, density contour
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
how to set Boussinesq model for homogeneous binary mixture richard2000 CFX 3 September 14, 2010 03:04
Model foaming process: change the volume / density pmp77 CFX 0 November 18, 2008 09:53
Density model ritmat FLUENT 0 May 16, 2007 09:29
about boussinesq model appleyy FLUENT 4 April 3, 2001 20:42
