wall surface reaction
Old   November 20, 2003, 13:14
Default wall surface reaction
vculiu
Thanks you for your time and reply.
I have a species transport model with wall surface reaction A+B-->C. The reaction is diffusion controlled, so I set pre-exp k at large value (>1E10) (activation energy 0). I found when k is large enough (such as >1E10 in my case), the surface concetration of A and B (CA and CB) as well as the reaction rate R(kg/m2s) are no longer changing. But the definition of surface reaction is R=k*CA*CB. When R is maintained same and k is increasing, CA and CB should decrease. Anyone can explain this?
Thanks
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
surface reaction, porous media Ali FLUENT 2 March 31, 2016 17:26
Surface reaction rate temperature dependence tumbao FLUENT 1 February 17, 2011 09:14
Wall surface reaction problem llnudt FLUENT 0 March 14, 2007 09:43
wall surface reaction Razvan FLUENT 0 April 5, 2005 05:10
