hostfile format
Old   November 20, 2003, 10:05
Default hostfile format
Wenbin
I am trying to submit parallel fluent job to a linux cluster, however, I have to use the job scheduler on the cluster, with this scheduler, I can only specify the number and type of nodes I intend to use, not the node name. The nodes will be make available by the scheduler, therefore I need to dynamically compile a hostfile, but I could not find an example of hostfile,
Can anybody give me an example of hostfile, or indicate a place where I can find such files
Thanks. Wenbin
Old   November 20, 2003, 11:50
Default Re: hostfile format
ccc
one host name per line if the host has two or more cpus, you should follow the host name by ":" and then indicate the number of cpus.
good luck
NASTRAN Data format Srinivasan Arunajatesan Main CFD Forum 1 January 2, 2014 06:20
msh format Frank FLUENT 1 June 27, 2012 10:39
Best format for simulation data? cbisw Main CFD Forum 9 May 30, 2011 02:38
Export to Abaqus input format jai CFX 1 July 21, 2010 04:53
OpenFOAM native format data visualization and workflow zeliboba OpenFOAM Post-Processing 0 September 12, 2008 08:44
