December 26, 2003, 19:55 |
compiling a UDF
I am trying to follow the steps in the UDF manual at
7.3.3 Compiling and Building Your Shared Library to compile a particular UDF. When I give the nmake command at the command prompt, I am getting the following error -- R:\1\libreactor\ntx86\2d>nmake clean Microsoft (R) Program Maintenance Utility Version 6.00.8168.0 Copyright (C) Microsoft Corp 1988-1998. All rights reserved. Could Not Find R:\1\libreactor\ntx86\2d\*.dll Can someone tell me what is going on ? What am I doing wrong ? |
December 29, 2003, 06:36 |
Re: compiling a UDF
If you compile udf in windows, you'd better install one c /c++ compiler, e.g. visual c++ 6.0, and make sure that all the necessary dynamic library files are installed. Hope it helps somehow.
Emma |
January 5, 2004, 19:34 |
Re: compiling a UDF
Can't say I've done this under windows, but....
"nmake clean" is probably designed to clean up the files created by compiling the UDF. I imagine it is trying to delete all the .dlls, but in this case you don't have any. I am not familar with microsoft make, but under unix you can do something like: make -k clean which ignores errors. Alternatively open up the Makefile in a text editor, and see what it is doing. |
About UDF compiling issues: 'nmake' | Haoyin Shan | Fluent UDF and Scheme Programming | 15 | November 4, 2019 18:05 |
Compiling UDF on a cluster | Adya | FLUENT | 1 | December 14, 2009 11:30 |
UDF compiling problem in Flient 6.3 | jeevan kumar | FLUENT | 2 | February 25, 2009 00:43 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 07:14 |
On Compiling a UDF | David Chabot | FLUENT | 5 | May 20, 2005 09:13 |
