December 29, 2003, 12:36 |
floating point error
I am calculating cavitation in a servo valve(3d)using RNG turbulence model. After 130 iterations, I got some message as following: Error: floating point error: invalid number epsilon equation: tol. 1.#INFe+00 0 1.#INFe+00 1 1.#QNBe+00 2 1.#QNBe+00 . . . . . . This means epsilon is too big to get the adequate turbulent viscosity? Any suggestion is highly appreciated. |
January 1, 2004, 00:48 |
Re: floating point error
check ur boundary conditios carefully.
also lower the values of under relaxation factor and use the coupled implicit solver hope this will help |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
Problem with UDF compiling for kTkLW model | Wantami | FLUENT | 0 | July 18, 2011 05:11 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
