Floating operating pressure
Prev Previous Post   Next Post Next
Old   January 14, 2004, 04:15
Default Floating operating pressure
antun
Hi all
I have a closed volume-piston arrangement and would like to compress the fluid inside slowly. The Floating pressure option seems to be only available if I specify the segregated solver and an ideal gas. I would like to use the user-defined real gas model, but this only works with coupled solvers. Is there anyway to force the floating pressure option or another way around compressing a user-defined fluid in a closed volume
thanks in advance antun
Variable Operating Pressure (field) Arturo FLUENT 0 April 30, 2008 15:22
Operating Pressure (Natural Convection problem) Andrew Tress Main CFD Forum 1 July 3, 2006 16:00
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Operating Pressure D Harvey FLUENT 0 June 4, 2004 13:12
floating operating pressure Shankar FLUENT 1 January 30, 2004 04:08
