January 20, 2004, 00:59 |
atomizer
I want to modeling spray of fluid from atomizer. I know that the flow regime in the atomizer is turbolence. I want to model this case by "VOF" and use the K-Epsilon standard model in the FLUENT package. But I dont know what kind of "Turbulence Specification Method"is used in this case and what value should be assigned to their parameters in the inlet and outlet of atomizer :
"K & Epsilon" or "Intensity & Lenght Scale" or "Intensity & viscosity Ratio" or "Intensity & Hydraulic Diameter" Thanks for your helps H.Masoudi |
January 20, 2004, 06:15 |
Re: atomizer
Hello
Why do you use DPM(Discrete phase model) instead of VOF, because DPM creates atomizer automatically. |
January 21, 2004, 02:22 |
Re: atomizer
hello mr. "Hadi Meshkati" thanks for your response
Because this case of atomization is doing in the free air (atomosphere) and the inlet air around the atomizer is not exist I can not use DPM. inlet gas from around of atomizer is necessary condition for using DPM in fluent.(section"21.1.3" of FLUENT6.1 HELP) It should be noted that bondary condition used in the inlet and outlet of atomizer are "pressure inlet" and "pressure outle" |
rotary atomizer | eng_norouzi | CFX | 12 | August 14, 2012 19:14 |
doesnt have disk atomizer! | eng_norouzi | CFX | 2 | August 14, 2012 07:47 |
Pressure Swirl Atomizer | Vijay | FLUENT | 0 | August 8, 2011 11:12 |
atomizer modeling | ganeshkthulasi | FLUENT | 0 | May 7, 2010 01:23 |
pressure swirl atomizer in 2d Axisymmetric | kev | FLUENT | 0 | December 6, 2005 00:10 |
