Working with sails
Old   February 2, 2004, 06:34
Default Working with sails
javier
Hello, i have a problem meshing my sails in gambit, iīm studing it lilke a infinite thin layer, like a membrane. The problem is how can i mesh my sails without making with it a volume, i explain it better. My control volume can`t contain a 2d form becouse i cant substrate a 2d from a 3d form, thatīs why i have to do volume whit my sails. Iīm asking for other way to do it beacouse doin a volume can be dificult with some sailīs forms.
Thanks
Old   February 2, 2004, 07:01
Default Re: Working with sails
mateus
Hi!
Why don't you construct your domain from more then one volume. For example. Volume in frot of the sail, volume behind the sail (these two shere 1 face - your sail geometry defined ac wall bc) and four more volumes on each side of the sail. This should work for you.
Regards MATEUS
DPM parallel is not working but serial is working johnwinter FLUENT 1 March 27, 2012 02:01
Modelling 2d sails with masts in Fluent panosna FLUENT 0 February 28, 2010 12:52
Working Principle of Micro-Oven aero Siemens 2 January 31, 2007 05:00
Help required on working of Micro-oven aero CFX 4 January 19, 2007 08:21
Help required on working of Woven aero FLUENT 0 January 16, 2007 06:25
