February 7, 2004, 15:12 |
to take K & Cp as temperature dependent
hello, friends,
i am using solidification/melting modules of fluent for solving freezing problem , my problem is of unsteady state, my problem is that i am unable to incorporate the physical property such as thermal conductivity and specific heat as temperature dependent, any body having having slution for the same , let me no. thanks in advance . with regards kishore |
February 17, 2004, 04:33 |
Re: to take K & Cp as temperature dependent
Fluent is able to define both properties as a temperature function. Piecewise-linear and piecewise-polynomial, polynomial are default function. Check the pull down menu in DEFINE-MATERIAL-Cp, and thermal conductivity. Thank you FJ |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Temperature Dependent Fluid Properties | eliwide | OpenFOAM Running, Solving & CFD | 4 | December 15, 2012 19:21 |
Adding a new temperature dependent viscositymodel? | dgadensg | OpenFOAM Programming & Development | 10 | May 22, 2010 05:47 |
Multicomponent with Temperature dependent | SAKTI | Siemens | 3 | September 15, 2008 22:09 |
Time Dependent Temperature Dependent BC Analysis | RP | Main CFD Forum | 1 | March 28, 2008 01:22 |
